I need your opinions
Old May 1, 2005 | 03:24 PM
gordis's Avatar
gordis
Default I need your opinions
Ok, I got a 1994 Honda del Sol VTEC (b16)
It has 131k miles
I already got exhaust system and intake. What should be next since i got so many miles--nitrous system, turbo, or head unit?
I need some good ideas.
I don't think I am gonna bother on a full swap, this year at least, but I am planning on 1 big upgrade for 2005. What do you think?
Old May 1, 2005 | 03:29 PM
KJJ's Avatar
KJJ
Drive Hard
whats the plan for your Del. Show or Go?
Old May 1, 2005 | 03:31 PM
gordis's Avatar
gordis
GO. i have grown out of my ricer stage, i want a decent amount of h/p. but i need torque-a little bit more-my 111 lbs. just isnt cutting it.
Old May 1, 2005 | 05:00 PM
delsoldude's Avatar
delsoldude
then turbo it. I am not a fan of them, but they get the job done
Old May 1, 2005 | 05:03 PM
JoshJ's Avatar
JoshJ
bang bang.
is turbo good for a motor that has that many miles on it? i know you said you dont really wanna do a full swap, but thats what i would do and eventually turbo it.
Old May 1, 2005 | 05:07 PM
delsoldude's Avatar
delsoldude
you got a B16. Why would you want to swap?
And if you work on the weak points the engine should be fine
Old May 1, 2005 | 05:12 PM
gordis's Avatar
gordis
what are those points
Old May 1, 2005 | 05:17 PM
delsoldude's Avatar
delsoldude
Me, I am not sure on those things. I know it could use a block guard. Honda cylinders are free standing in the engine.(they are not connected at the top of the cylinder to anything) so with high HP it creats problems
Old May 1, 2005 | 06:08 PM
JoshJ's Avatar
JoshJ
bang bang.
Well, I believe I read somewhere that it is not good to turbo or add nitrous to a higher mileage engine, please correct me if I am wrong.
What do you want to do with the car? Is it a daily driver, autoX, drag? What are your plans, knowing that would help us give you more accurate suggestions.
Old May 1, 2005 | 06:09 PM
Snoopy's Avatar
Snoopy
been there done that
do a compression and leakdown test. if the numbers are good turbo that bitch.
or do a rebuild and then turbo it.
