CV shaft
Old Apr 30, 2005 | 06:42 PM
Bricks2k4civic's Avatar
Bricks2k4civic
Default CV shaft
I just replaced the right CV shaft on my 2004 civic LX, and when I drive, it pops out of the transmission, and neither wheel will turn. Also, I replaced the washer, and it still leaks. How do I fix this?
Old Apr 30, 2005 | 06:47 PM
Omniscient's Avatar
Omniscient
warm butter on toast
Are you sure there all the way in? I know it sounds dumb, but even if they look like there all the way in, they might not be.
Old Apr 30, 2005 | 06:52 PM
Bricks2k4civic
It might not be. When I tightened the 32mm, it pulled out a little. Had somewhere to go so I took the parents car. By the way....those hybrids can MOVE!! hit over 100, and the ride was still smooth. Too bad its auto.
Old Apr 30, 2005 | 06:54 PM
Bricks2k4civic
Is it safe to hit the other end of the shaft with a hammer to get it in?
Old Apr 30, 2005 | 07:05 PM
Omniscient's Avatar
Omniscient
What I did was covered the pinion part that goes into the tranny in grease, used a tire jack to keep it level, forced it in there, then used 2 hands to really work it in there, put the hub back on, hit the 32 mm with a rubber mallet, then did the 2 hand thing again, hit it with the mallot 1 more time, then used a breaker bar with a 10 foot pole from an old metal fence and stood on it untill it could hold my weight. Hasn't budged yet.
Don't know if it was ALL necessary, but the last thing you want is the axle pinions getting eaten up in the transmission.
Old Apr 30, 2005 | 08:14 PM
Bricks2k4civic
Ok, got it all done again. You were right, it wasn't in all the way. Hit it in with a hammer, then put everything back together. It leaked a little, but when I got both sides up and fired it up, it poured out. My uncle did an american car, and said there is only one true way to get it in so it seals. Is that true for mine? Hope my new springs go a little better than this.
Old Apr 30, 2005 | 10:53 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Did you use new set rings?
Why are you already changing the axle on a virtually brand new car?
Old May 1, 2005 | 10:28 AM
Bricks2k4civic
new set rings? I'm replacing it because I drive hard and a lot. Got the car in sept. and have over 10k miles on it.
Old May 1, 2005 | 11:22 AM
alphaxxn's Avatar
alphaxxn
4500rpm hesitation
even so they should'nt have needed a replacement already.
Old May 1, 2005 | 09:42 PM
SmartySarty's Avatar
SmartySarty
was the axel making a poping sound or even broke, did you pay for the whole new axel, dont you have warrenty on the axel if it brakes. y didnt you just wait till it broke
