B20 Build Q?
Old Apr 30, 2005 | 12:10 AM
b20hatchy's Avatar
b20hatchy
EM1 Crew member #74
Default B20 Build Q?
Well its time to start the build up of my b20! I just wanted to see if anyone has done a build on a b20 or has heard of one that put some good numbers down? I am still staying turbo but i'm going full bottom end and a built b16 head. The things that i have decided on that will happen for sure will be: Darton Sleeves, crvtec conversion. 8:1 compression.
Old Apr 30, 2005 | 11:13 AM
TeHJuSTiN's Avatar
TeHJuSTiN
NAM #0001
Why so low compression?
Old Apr 30, 2005 | 01:15 PM
Ziken's Avatar
Ziken
RACE USE ONLY
Ive heard you can push 300hp with just the stock head and block and run the turbo at 10 psi
Old Apr 30, 2005 | 08:50 PM
alphaxxn's Avatar
alphaxxn
4500rpm hesitation
check out widebodyek's numbrrs
600+ hp with CRVTEC setup , your C/R's remind me of his.
my CRVTEC setup will be running 10.5 or so.
Old May 1, 2005 | 01:50 AM
Ziken's Avatar
Ziken
RACE USE ONLY
Im going for a NA build. I should get at least 250.
Old May 1, 2005 | 08:43 AM
alphaxxn's Avatar
alphaxxn
4500rpm hesitation
Sounds fun, I was tempted to do a NA build so I could enjoy the twisties more, but I guess I can just turn down the boost
Old May 1, 2005 | 09:38 AM
Snoopy's Avatar
Snoopy
been there done that
250whp NA is not going to be easy or cheap
