upgrades
Old Apr 27, 2005 | 07:29 PM
Mr_Goodbar's Avatar
Mr_Goodbar
Default upgrades
Im totally new to this stuff so bear with me. I have a 97 civc DX coupe thats totally paid for with 100k miles. I think that it would be more cost efficient to just swap engines when this one craps out but i want my car to be fun to drive now. I want to put coilovers, wheels and tires, sway bars, and better brakes on now to at least improve ride handling. My question is if i get upgrade parts such as exhaust, intake, etc., will they be easily interchangeable with the new engine? Thanks a lot.
Old Apr 27, 2005 | 07:34 PM
igo4bmx's Avatar
igo4bmx
CockBlockerator
intake - depends
exhaust- should fit fine
header - from d to b - no
Old Apr 27, 2005 | 08:14 PM
Mr_Goodbar's Avatar
Mr_Goodbar
thanks that helps. I wouldnt get the headers until i swapped anyways. and i take it that i should be fine with the suspension stuff.
Old Apr 27, 2005 | 08:20 PM
alphaxxn's Avatar
alphaxxn
4500rpm hesitation
The suspension stuff will in all likelihood be fine.
Intake is USUALLY okay.
Headers definetly not unless you swap another D.
Suspension+steering+brakes are the most fun upgrades anyway instead of speed it just makes it more fun to drive
Old Apr 27, 2005 | 11:59 PM
Mr_Goodbar's Avatar
Mr_Goodbar
can I put power steering on my civic DX or is that just a stupid idea cuz its pretty small as im sure everyone knows?
Old Apr 28, 2005 | 12:13 PM
Jafro's Avatar
Jafro
I'm made of meat!
FYI, exhaust pipes may also not fit. If you have a HX, VX or CX, whatever you bolt in there that fits those engines won't fit any other D-series unless you replace everything all the way up to the head. No D - B series intakes, intake or exhaust manifolds are interchangeable across engine codes. D-series fits D-series, B-series fits B-series.
Power steering is possible but you need to replace the rack and that's a crappy job. You're better off without it anyway, your car only weighs 2300 lbs.
Old Apr 28, 2005 | 01:51 PM
meunit910's Avatar
meunit910
Why bother adding power steering. I don't thinks its worth the money if your car doesnt have it. An when you swap you will be moving faster with the rpower steering, Depending on which motor you get.
Old Apr 29, 2005 | 04:46 PM
Jafro's Avatar
Jafro
I'm made of meat!
Correct. There are DX model civics that came with power steering, so it will add literally nothing to your car's value. The manual rack is also more popular with the racers and tweakers because of the turning radius and lighter weight.
Old Apr 29, 2005 | 11:49 PM
SmartySarty's Avatar
SmartySarty
Exhuast for that car is fine thats what they invented saws, flanges and welders for...............
Not header tho
Old May 2, 2005 | 03:09 AM
Mr_Goodbar's Avatar
Mr_Goodbar
ya thats what i wanted to know about the exhaust; if it could be modded w/out a problem. I have acess to some TIG welders at my uncles shop and i figured that the header would definitely not fit. thnx for the help guys.
