What did you do when you put in a deck? [DC/DB Integra]
I have the stock sound system in my SE, where it has the radio and the CD player above it. When you guys put in a deck what did you do with the empty spot? I wanna put in a deck, but i dunno what to put in the empty spot
Does anybody have picturers?
Not sure if it's the same but you can probably buy the OEM pocket from the dealer or from someone here as well. They also have the kits that fill up the space, which puts your deck in the middle of the double DIN area. Personally I think the pocket looks better though and somewhere to put your phone when it's charging!
Moved to Audio & Security.
When I bought my single DIN headunit from Crutchfield, they included a panel kit that mounts the deck at the top of the dual-DIN opening, and has a small slot-like trim panel underneath.
Because of the bulk of the wiring harness, I haven't reinstalled my stock pocket. For me, it's no big loss. I'm more concerned about securing the headunit anyway.
Look around on the net and you'll find a range of dual to single DIN conversion kits. You may need to do some additional fabrication work, but the retail kits are a good place to start.
Does anybody have pics of what they did in their integra? Cause i'm sure alotta people got systems in their tegs. I'm looking for those DIN conversion kits, can anybody suggest a good one or good web sites to check out for them?
Thanks for the replies!
Mine actually came with a pocket, but I bought one of those mounting kits from Best Buys. It costs about $15. I cant remember off the top of my head what the brand it. The coloring is slightly off. It is more of a gray than black like my center console.
some people say you dont even need the mounting kit, its better without it. You just use the stock pocket. Alotta people say the mounting kits dont fit very good.
Is this true? Now i dunno if i should use a mounting kit or not
