automatic to 5 speed swap.
Old Apr 19, 2005 | 01:01 PM
batlbrandon's Avatar
batlbrandon
kanichiwa
Default automatic to 5 speed swap.
I have swapped a 5 speed into a 97 prelude automatic (H22 non-sh). I was wondering am I going to have problems with ecu's and wiring?
Old Apr 19, 2005 | 02:03 PM
5hift's Avatar
5hift
Hades: 2.2L DOHC VTEC
You'll need a 5 speed ECU and wiring harness. Wiring from OBDII to OBDI is a bitch unless you get an OBDII oil pump to plug into the OBDI distributor.
Old Apr 19, 2005 | 02:50 PM
batlbrandon
kanichiwa
thanks, but I am doing straight obd II. and is that supposed to be funny?
Old Apr 19, 2005 | 03:22 PM
ludeboom's Avatar
ludeboom
1. - no its true obd2 h22a4's pickup crank signal from oil pump instead of dissy
2. - u should be able to get away with a base ECU (NON SH) from a 5spd 5th gen lude. All the plugs should fit and it should be mostly plug and play except that your cluster has automatic lights for gear selector position
Old Apr 19, 2005 | 04:18 PM
prelood's Avatar
prelood
:rofl: olong: :fawk: :jlammy:
Old Apr 19, 2005 | 05:30 PM
5hift's Avatar
5hift
What's humorous about anything I typed?
Old Apr 19, 2005 | 06:00 PM
ludeboom's Avatar
ludeboom
shut up bitch
Old Apr 25, 2005 | 05:48 PM
batlbrandon
kanichiwa
the gauges are not a problem since this car is getting a custom fiberglass dash, and all gauges are being replaced with stewart warner ones. thank you for the help.
Old May 11, 2005 | 03:44 PM
stereo's Avatar
stereo
if your replaceing the SS to manual in a 5th gen you need the 5sp ECU (red learn key for immobilizer) trans,right trans mount,speedsensor, flywheel + bolts) shift linkage,pedals ,shifter &boot , gauge cluster if you don't like the PRND4D321 on the dash you can use your auto harness and just leave the trans stuff unpluged just have to locate the reverse light wires or get a manual one.
Old May 11, 2005 | 08:47 PM
btdesalvo's Avatar
btdesalvo
how much did it cost you to do the auto to 5spd swap ? and did oyu have it profetionaly done or did you do it ....?
