Problem with heat/AC always being on...
Old Apr 14, 2005 | 12:48 PM
tdcdodger's Avatar
tdcdodger
Default Problem with heat/AC always being on...
last week i installed some intake on my car.
a couple days ago i noticed that my AC/heat was always on, even when the fan speed thing was off. If i move the dial to red it will make hot air, blue cold.
Im wondering if i might have bumped the AC pipe in my engine bay while installing the intake, cause the filter is right below it.
Lemme know what you guys think.
Thanks in advance
Old Apr 14, 2005 | 01:35 PM
blacklude's Avatar
blacklude
try to remove the blower motor fuse and see if it shuts off. it might be possible you have a short in the circuit.
Old Apr 14, 2005 | 02:47 PM
2legit2quit's Avatar
2legit2quit
You Big Dummy
Does the air blow hard, or is it just a slight breeze?
Old Apr 15, 2005 | 08:27 AM
VPUPPY's Avatar
VPUPPY
is your air recirculation button on the off position?
Old Apr 16, 2005 | 12:38 PM
tdcdodger's Avatar
tdcdodger
its a slight breeze i would say, definitly less than when the fan speed is in the 1 position
ill try that thing with the fuse, thanks for your help
Old Apr 19, 2005 | 06:45 AM
bigt61's Avatar
bigt61
On hondas if you have the outside air circulation button pushed, it slightly draws air from the outside and causes a little breeze. It is because the valve is open when you push outside air, even with the fan switch off.
Old Apr 19, 2005 | 07:03 AM
2legit2quit
You Big Dummy
Yeah, thats what I think his problem is.
