93 Del Sol SI Turbo FS Northeast Ohio
93 del sol si for sale - car was just sprayed dark silver last month- here is a list of mods email or post if interested- 155k on body 100k on engine. over 15k invested in this car. some little flaws but nothing major. many other parts i have for the car waiting to be installed but will be able to be bought with the car if your interested. If there not bought with car they will be put on seperate post - i have some pics but dont know how to post but i can send in an email. pictures are bad quality but will give you an idea. i will take more pics when the weather cleares up a little. located in northeast ohio. if im forgetting anything i will post another topic, Thanks you
Engine: D16z6 around 100,000 miles - Boosted for around 6k
Fmax log style manifold with deltagate external wastegate( 7.5pd wastegate)
Painted mandrally bent IC piping with Blitz Superseqential BOV
FMIC (not sure of dimensions)
2 1/2 downpipe
T3 60trim turbo
Walboro 255lph fuel pump
Skunk2 IM
AEM ADJ cam gear
ACT 8.8pd flywheel
Centerforce Dual friction clutch(installed new tranny seals when clutch was replaced 10k ago)
New driveshafts with lifetime warranty
Zex dry nitrous system with purge and guage mounted in glove box
2 1/2 test pipe with 2 1/2 exhuast piping to muffler
modine illuminum radiator
Exterior:
Just sprayed Dark Silver ( base coat clear coat) driven only 5miles on paint
custom decal sprayed on side of car( not a sticker) black and burnt orange
shaved moldings and antenna
Clear Corners
Black JDM housing tail lights
VIS invader style hood
VIS Bullet Fenders
VIS Mugen front bumper( FMIC mounted in middle)
Wings west side skirts
Wings west rear lip
17" black wheels with polished lip( just installed 5miles on tires)
Black tinted windows
5 1/2 in velocity stack in front bumper( working with turbo)
Interior:
Custom Roll Bar behind seats
VAFC2
Momo steering wheel with hub
Carbon fiber dual guage pod
Autometer phantom guages- Boost , Volt, Air/fuel, water temp , Nitrous pressure,
5" autometer phantom tach w/ shift light
Custom glove box with 2switches and space for 3guages and carbon fiber cover
short shifter with greddy trust shift knob
Stereo:
JVC MP3 Player
8" Cadence speakers in doors
12" Diamond Audio Sub in Ported Box in trunk
400W mono block amp
Brakes:
Brembo slotted/ drilled sinc plated rotors all around
Ceramic brake pades in all corners as well
Suspension:
Front upper strut bar
rear upper strut bar
rear lower tie rod bar
Tokico 5way ADJ struts( all 4)
H&R Race spec 2 3/4in drop(all 4)
Front controller arm polyurethane bushings
Camber Kit ingalls
2 1/2 downpipe
T3 60trim turbo
Skunk2 IM
AEM ADJ cam gear
ACT 8.8pd flywheel
Exterior:
Clear Corners
VIS Bullet Fenders
Wings west rear lip
Interior:
VAFC2
Stereo:
JVC MP3 Player
400W mono block amp
Brakes:
Suspension:
Camber Kit ingalls
