custom shift light question?
Old Feb 13, 2005 | 06:04 PM
g2_teg_na's Avatar
g2_teg_na
^ Visual Learner
Default custom shift light question?
i have an empty space on my dash where a power mirror switch usually goes. to fill it in, i want to make a neat little shift light thing. i dont really need a shift light, i'd just like to rig one up as somethin cool to have. here's my plan:
3 little LEDs -- one red, one yellow, and one green.
all three set to light at different RPMs -- red: 100 rpms -- yellow: 5000 rpms -- green: 6800 rpms (redline)
one/off toggle switch -- so that i can have them all working, or none.
if you guys understand right, then you'll get that im trying to make it look like a stop light, where the light either changes, or the next light comes on at higher RPMs. heres a pic so u can get a better view of what i plan on doing.
now here are my question:
How will i hook these LEDs up to know what RPMs my car is revving to?
File Type: bmp
Old Feb 13, 2005 | 06:59 PM
VPUPPY's Avatar
VPUPPY
you need to create a circuit board with a DOT/Bar Display Driver(an actual semiconductor chip) that senses A/C voltage for the leds. this would need to be hooked up to your tach wire(which works on A/C voltage, the higher the voltage, the higher the RPMs are). it would probably be cheaper and easier to buy one off the shelf rather then create your own.
Old Feb 13, 2005 | 07:06 PM
g2_teg_na's Avatar
g2_teg_na
^ Visual Learner
how would i do that? u have any websites that'd explain that to me?
Old Feb 13, 2005 | 07:26 PM
VPUPPY's Avatar
VPUPPY
to get an idea, take a look at this custom air/fuel meter:
http://www.scirocco.org/tech/misc/afgauge/af.html
Old Feb 13, 2005 | 07:37 PM
g2_teg_na's Avatar
g2_teg_na
^ Visual Learner
thanks....kinda confused now though.
Old Feb 17, 2005 | 09:09 AM
bxsnypa's Avatar
bxsnypa
STOCK EJ8 noob
when u get ur shift light installed please post a pic i would be interested in seeing that
Old Feb 17, 2005 | 09:11 AM
g2_teg_na's Avatar
g2_teg_na
^ Visual Learner
if i can ever figure out how to get it done...
Old Feb 17, 2005 | 09:19 AM
94JR's Avatar
94JR
I was thinking about replacing a shift light for my dash dimmer nob on my 94LS. It seems to be a good place that would look like it was ment to be there
Old Feb 20, 2005 | 08:01 AM
VPUPPY's Avatar
VPUPPY
the basic idea is that you have a chip(driver chip) that gets a signal from a wire(tach wire). when that chip detects a certain A/C Voltage(thats what the tach wire sends) it turns on a corresponding LED. sorry i could not be any more specific but I have never had to build one of these. the hardest part should be getting the chip(one that reads A/C voltage) and programming it. you need to know the A/C voltage output at specific RPMs to correctly program the chip. if you look online for "semiconductor chip" and your city name you may find some places that you could call to see if they offer a LED driver chip that takes A/C voltage as an input.
Old Feb 20, 2005 | 08:03 AM
VPUPPY's Avatar
VPUPPY
btw, like I suggested before, it may be easier to buy a off the shelf shift kit and installing that, unless you want to learn how to make them.
