DIY 95 accord. clean out your dirty A$$ window switches (picz)
Old Feb 11, 2005 | 10:00 AM
DaNnYsEvEn's Avatar
DaNnYsEvEn
ThInK PiNk!
Default DIY 95 accord. clean out your dirty A$$ window switches (picz)
most people think a window switch has gone bad just because the window wont roll up anymore when you tap the switch. in most cases a simple cleaning will do the trick (rather than having to go and buy a new master switch for 50 bucks on ebay!). in this diy i did it on the master switch on my 1995 honda accord ex 4 door.
disclaimer: i am not responsible for anything that happens to your car if you try this.
1. first screw out the screw thats inside the lil coin holder thing.
2. pry out the master switch from the side making sure you dont snap it in half (this is kinda tricky)
3. disconnect the green switch.(used for power mirrors)
4. disconnect the grey switch.(used for the power locks and windows) and the brown switch thats right above it.
5. after you have done that the master switch should be out without any wires attached to it. now turn the master switch around and there are 3 screws to take out.
6. after you do that the whole switch system should come out and should look like this
7. now remove the little black switch caps (there are 4 of them for 4 windows). you can pry them out with a flat head screw driver. have patience! this is also a lil tricky
8. now that that the switch caps have been removed you can remove the black rubber piece.
9. now that everything thing is exposed you can remove the lil white switch using a small flat head screw driver.
10. once that is done you will see the inside of the switch. you can see that all the dirt has built up and cloged the connection from making contact. (this sorta works like the post of the battery when all the crust has built up and keeps your car from starting) well this is what kept your window from rolling up or down. get a small flat head screw driver and start scraping away the dirt from the metal.(make sure its cleaned out good)
11. inside are 2 little "v" shape pins, take them out and clean them out as well
12. after you clean out everything and scrape it up so it can make a connection, your all done. reverse the process to finish the job...everything should be working fine after this. (remember that i only did this for one of the switches. there are 4 of them. you can do this to all 4 if you would like or just do the one that is not working. this is my first diy and i hope it helps yall out a lil bit. sorry about the pics, i used the camera phone since i dont have the real digital camera. well good luck and have fun!!!
well thats about it...PEACE!!!
Old Feb 11, 2005 | 11:05 AM
JL95AccorD's Avatar
JL95AccorD
Cool. I'll definately try this out tomorrow. I thought I was going to have to buy the complete peice new, or go and find one at a junk yard. Thanks.
Old Feb 11, 2005 | 10:17 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Good writeup. Nice to know that there is someone who cares about the little things.
Old Feb 12, 2005 | 06:29 PM
DaNnYsEvEn's Avatar
DaNnYsEvEn
ThInK PiNk!
thanks! well just tryen to look out for those who want to save some money!! (like myself!) and those who want to take care of their "babies" and keep them clean!
Old Aug 25, 2005 | 09:22 PM
drslowens's Avatar
drslowens
Default Thank you
Cleaned the power window switches as you described and with only one slightly broken piece of plastic, all the windows now work. thanks
Old Aug 26, 2005 | 04:34 AM
lkailburn's Avatar
lkailburn
college kid
very nice bro. the little writeups are where its at.. i have manual windows tho o well heheh
Old Aug 26, 2005 | 09:21 AM
fjm1's Avatar
fjm1
G35
great writeup!
