replacing bulb in enviromental contrl panel
Old Feb 8, 2005 | 09:32 PM
prelude97's Avatar
prelude97
Default replacing bulb in enviromental contrl panel
I have a 97 cl and the bulb behind the [off][auto][temp up][temp down] is burned out.
Is this easy to replace? Anyone done it?
I've removed the glove box, pryed off the wood trim from above the glove box but couldn't get it off where the environmental panel was - the trim got thin and didn't want to pry anymore.
Thanks,
Jay
Old Apr 1, 2005 | 10:35 AM
DARKUV's Avatar
DARKUV
Try Carefully Removing All Of The Above That You Attempted Before And Include Careful Removal Of The Crome Trim Around The Shifter. Then Remove The Ashtray Which Should Reveal More Screws Behind It. This Should Loosen The Entire Center Council.
If You Have Nay More Trouble You Can Just Post It And Ill See What I Can Do
