Help! tranny leaking
Old Jan 31, 2005 | 07:39 AM
oc9crx's Avatar
oc9crx
Default Help! tranny leaking
The tranny on my crx is leaking so I jack up the car and look under and it seemed to be leaking from where the axle meets the transmission so I was told to replace the axle seal, so I did but its still leaking. Any other possibilities.
Old Jan 31, 2005 | 08:54 AM
12yearhondatech's Avatar
12yearhondatech
The axle seal should of fixed the leak unless there is a nick on the inner cv shaft where the axle seal rides or maybe you did not get the axle in all of the way it should almost be flush with the trans. Possibly you may have damaged the new seal when you installed the axle, after installing the new seal you need to grease the inner grove off the seal and also put grease on the inner cv shaft where it slides into the trans. make sure the inner cv does not touch the new axle seal when installing because it can tear very easy.
