Vtec question for newbie
Old Jan 11, 2005 | 05:59 AM
oldcivic's Avatar
oldcivic
Default Vtec question for newbie
What is the Rpm engagement point and oil pressure reading for a mini-me conversion of a b15y7 block
Old Jan 11, 2005 | 06:44 AM
dustimus's Avatar
dustimus
Better golfer than you
Whats a b15y7??????
Old Jan 11, 2005 | 08:07 AM
b16ahybrid's Avatar
b16ahybrid
I'm going to take a stab at this one.
I believe he means d15b7.?
Anyways the correct way to find the rpm where the cams should switch over is on a dyno. Doing so otherwise is pointless and you could be losing power.
Old Jan 11, 2005 | 08:08 AM
honda_pilot's Avatar
honda_pilot
DeeCeeFo'
I dun think thats a noobie question :dunno:
Old Jan 12, 2005 | 09:22 AM
vinnyzcrx's Avatar
vinnyzcrx
no theres a d15y7, its in the 92-95 civic hx. it would be a hassle because that engine came duel carborated. i dont really see the point in putting vtec on a carborated engine. convert it to fuel injection first then add vtec. i recommend the 99 civic ex intake manifold.
Old Jan 13, 2005 | 04:49 PM
b16ahybrid's Avatar
b16ahybrid
Where is this suposed obd-1 carborated civic? I believe everything from 1988 up is fuel injected.
The Hx didn't come out till 96 and only the dx,si,ex,vx,and cx were available inthe 5th gen civic.
They are all fuel injected.
The hx came with a 115hp vtec-e
Old Jan 13, 2005 | 07:43 PM
yellow civic ex's Avatar
yellow civic ex
ghey slow d16 modder
if you're just using the ex ecu then it's around 5800rpm.
