FS:1991 Crx Si,b16 project *Upstate NY*
Old Jan 2, 2005 | 03:46 PM
mistacee's Avatar
mistacee
Zc powered ED9
Default FS:1991 Crx Si,b16 project *Upstate NY*
Bought an Integra ,so this project is FOR SALE!!!
Here are the specs -
1991 Honda Crx Si
-Clean Title
-134k on chassis
-JDM b16a1 Motor (50-60k on it)
-LS Transmission w/y1 gears
-ACT 6 Puck Clutch w/extreme pressure plate
-ACT 12.5 light flywheel,chromolly
-Driveshaft stage 2 axles
-Hasport Shift linkage w/short shifter
-Hasport Motor mounts
-New Placing Racing Crossmember w/4th motor mount
-JE Pistons 9:1 Compression
-Eagle Rods
-Knifedged Crank
-Type R Oil Pump
-Type R Water Pump
-Type R Valves,Valve Springs,Reatainers and Cams
-Brembo Stainless Steel brake lines (Fronts installed,rear ones not)
-MSD 6al Box
-MSD Blaster 2 Coil
-High Flow Cat
-2 1/2" Exhaust w/4 1/2" Muffler
-Neuspeed Race Springs
-KYB 3way Adjustable Struts
-Neuspeed Front Upper Strut bar
-Neuspeed Lower tie bar
-15" Dodge Omni GLH Wheels w/3 new tires
Story:
The car was a built to be a turbo project car,but plans changed and decided to run it N/A.The car turns over and has run before.It does not run now as it needs some minor things in order to run again.It had an oil leak by the oil pump,(bad O Ring) but i had that fixed.The car needs to be completed.Needs plugs,battery,oil pan reinstalled valve cover secured and various gaskets(which i have and are included).It would not take much for this car to be running.Basically this is a project that i never finished and no longer have the time and money to do so.
As for the mechanicals, I believe everything works great. The speedo cable needs to be popped back into the tranny.
Interior is in good shape as well,seats are in very nice shape!The body of the car is nice too,some surface quarter panel rust just starting,nothing major at all!
I have stainless steel brake lines with it as well. They are installed on the front but not yet on the rear. The brakes need to be re-filled and bled too.
Lots of goodies with this car,so am asking $3950.00 OBO.
Any reasonable offer will be considered.
Car is located in Upstate Central NY.
Contact me via Pm,phone or email.
Cory 607-533-4877
PICS:
Old Jan 3, 2005 | 01:41 AM
mistacee's Avatar
mistacee
Zc powered ED9
Not one reply,no one is interested?
Old Jan 3, 2005 | 07:23 AM
ISP James's Avatar
ISP James
DAMIMRED
dont really know that i want the car but i do see that you swapped your pistons.... do you still have the b16 pistons? im about 1-2 hours from the 607 depending on where you are, lemme know ill buy them from you.
bump for a central ny'er :bigok:
Old Jan 3, 2005 | 10:53 AM
mistacee's Avatar
mistacee
Zc powered ED9
Sorry i don't have the stock pistons,plus i am not looking to part this out.I bought a GSR so this project HAS to go!
Thanks for the bump!
Old Jan 3, 2005 | 10:55 AM
ISP James's Avatar
ISP James
DAMIMRED
well i wasnt askin you to part it out, just to lemme buy your b16 pistons from you
im gonna send you a PM to help you sell this thing :goodjob:
Old Jan 3, 2005 | 03:08 PM
mistacee's Avatar
mistacee
Zc powered ED9
Thanks for the bump and info!!!
Old Jan 16, 2005 | 07:40 AM
mistacee's Avatar
mistacee
Zc powered ED9
Bump for good deal on a solid Crx!!
C'mon ppl spring will be here soon,need this gone!
Old Jan 26, 2005 | 04:31 AM
mistacee's Avatar
mistacee
Zc powered ED9
WINTER PRICE DROP!!
$3000 w/94-01 Integra GSR(non leather) or LS front seats,must be in nice shape and BLACK!!
Old Jan 28, 2005 | 11:15 AM
mistacee's Avatar
mistacee
Zc powered ED9
Bump for a hell of a price/deal!
