1991 Integra SCCA Rally Autocross Open Track (New York)
Old Dec 31, 2004 | 01:35 PM
vinsterr50's Avatar
vinsterr50
Default 1991 Integra SCCA Rally Autocross Open Track (New York)
It is a rather serious race car, that can be driven on the street, if necessary. It has a 12-point cage (1.50 dia tubing with .120 thickness) with halo that goes to the front and rear strut towers and is SCCA Club Rally certified with SCCA vehicle logbook. It has a new rug, MOMO race buckets, and Sabelt five-point harnesses (I think they're expired by now.) Momo suede two-spoke steering wheel. Has oil pressure, oil temp and coolant temp gauges in the center console. The car has no AC and no radio or speakers. Heater and wipers are still in place and work fine, as required by rules. Has a milled stock head (more compression) with a valve job on the stock B18A. Has adjustable cam sprockets and a new timing belt. The tranny has a Quaife limited slip diff. Has a solid hub clutch, and a short throw shifter. DC Sports header, and full 2.25-inch exhaust. It has new Brembro replacement rotors and Porterfield pads. Polyurethane all around. Has a Suspension Techniques rear anti-sway bar. Bilstein dampers with stock springs for stock classes. It has 14-inch Audi Quattro wheels (kinda rare in itself) with shaved 205/55/14 Kuhmo V700 Victoracer tires with only one track day on it. I am including three more spare wheels, all white. It also has a cold air induction, and had a tune up about 100 miles ago with new cap rotor, wires and plugs. The car needs nothing for competition. You can register for the street it if you want, but the turnsignals don't work, probably needs some wiring. The other thing it has is a small trans leak by the drain plug. Everything else for the street is still intact. The paint is shiny and is in good shape. There are a few dings and scratches in the paint, and a minor dent on the driver's front fender, but the car has no frame damage at all. No rust, added a GS rear spoiler. This is a class legal race car that would cost you over $15,000 to build, on top of the price of the car! I'm losing my shirt on this, but I'm concentrating on my new MINI. Asking $4900. You can see it here also-
http://cgi.ebay.com/ebaymotors/ws/eB...e=STRK:MESE:IT
Thanks.
Old Jan 1, 2005 | 01:04 PM
axemansean's Avatar
axemansean
I would recommend the SCCA forums because only a few people will be able to use this car.
