Help on Building LS B18 for 8K rpms
Old Dec 30, 2004 | 01:40 PM
j87w's Avatar
j87w
Default Help on Building LS B18 for 8K rpms
Has anyone on here built a LS motor to handle 8 - 8500K rpms. I bought another LS motor and am going to build it up. I plan on using a girdle, having the crank balanced, going with a set of aftermarket race bearings, arp head, rod and main bolts, if i can find where the oil passage is ill have oil squirters installed, type R pistons .25 over, and a set of good forged rods. What you guys think bout it? Thanks J
Old Dec 30, 2004 | 03:49 PM
Snoopy's Avatar
Snoopy
been there done that
dont forget cams that will make power that high
Old Dec 30, 2004 | 11:00 PM
j87w's Avatar
j87w
Im going with a B16A head with a CTR intake cam I think it will make power that high. Is there any way to get the ITR pistons to fit on the some forged LS rods. You had said that stock pistons wont work with aftermarket rods so. Also how balanced is the LS crank from honda. Is it just as balanced as a GSR or no.
Old Dec 31, 2004 | 02:34 PM
exospeed*com's Avatar
exospeed*com
There's no point on going aftermarket rods if you are only using OEM cast pistons.
Also theres no need for aftermarket rods if you arent really building it up for MAX power.
I just answered a question like this at G2iC.com
here's what I replied at that forum:
dont see the need for Aftermarket rods, for a basic all motor setup. Keep in mind that aftermarket rods may be even heavier than stock rods.
Unless you are making loads of NA power, the stock rods are good enough.
The only time we recommend Aftermarket rods, are:
1. going turbo setup
2. Building a high hp NA setup with aftermarket pistons
