which one should i get first an exhaust or an intake?
If you get one you might as well get the other....The whole system depend on each other to get the max efficiency out of a car.
it really depends on how much money you have also on which one to get first. I myself got an intake first then a week later received my Apex N1 exhaust system.
Pull all the resonator and air pipe shit off of you stock intake so there's nothing before the air box and get a header. If you have money left over pull out your stock airbox and hose clamp a K&N filter that has the right diameter inlet to the end of it. Good as any intake IMO.
No me I would go with a set of 4-2-1 header's first after that remove almost ever restricting stuff on the exhuast system.( Unless you are getting a turbo )Cat back exhuast first 2'' to 3'' diameter pipe . I'm running 2 3/4'' pipe
Then get the aftermarket intake; New upgrade injectors ; then upgrade the spark plug wires to a low resistance set ; great aftermarket coil from MSD.
