Dizzy question 98 gsr hatch
I just wanted to ask does it matter which one i use for a 98 gsr hatch..... td 84u or td 87u... another thing can it run safely with just one bollt-washer holding the dizzy... I've read different post but just wanted to double check before getting a dizzy....
Any imput I would appreciate that,,,,
TD-84u and TD87u are different in terms of VTEC and NON-VTEC applications.TDxx model #s are assigned to almost all Honda OBD1 and OBDII engines, regardless of brand. As long as its OBDII (you can tell because it will actually plug in to your harness) I haven’t found a difference between an Integra VTEC and non VTEC distributor and have successfully interchanged them.
P.S. Spec R is one of the most helpful people Ive ever known - its cool to see you still helping and replying!
