89 CRX - B18a1***need to get rid of*** WEST Michigan **good price**
Street Corner
hi i need to get rid of my crx, too many things going on right now, i need the money so willing to sell cheap. 2000 dollars... this is my lowest price thanks.
i have a white crx HF w/ full SI interior (all black) swap , custom power windows usdm, very clean interior and descent exterior (except for a minor scratch by the gas tank which has started to rust a bit), tinted windows (except the drivers side which i have had to replace due to ignorant ghetto ass children who like to steal my stereos), push start button (everything there to connect, its just disconected at the moment because it got annoying when people wanted to test drive the car and couldnt turn it on), b&m short shifter, kyb agx adjustable struts, H&R springs, drum to disc conversion (discs from a 91 integra), front spindles changed to civic SI spindles (this is needed to do a integra engine swap), the old hatch was leaking so i replaced the hatch (unfotunatly the color of the hatch is red), all moldings painted white instead of being black.
Motor is a 91 integra Ls, with every gasket and seal changed including the valve stem seals (i think thats what they are called), and even the grommet things that go on the valve cover... so seriously every single gasket was changed. the dizzy was acting up so i replaced the ignitor, and the coil. the clutch kit is only 1 ½ years old. the swap was done with hasport motor mount kit and the shift link was cut and welded due to not having enough money, umm also i installed a walbro fuel pump...
the only real problem with this car is that i think it runs a bit ritch but i havnt been able to correct this because of lack of fpr. also i think it burns a bit of oil, i have to put oil in the car every month or so because it goes down from top line to 3/4 line on the dipstick. there is absolutely no leak so i know its not a leak, but sinse it uses up oil im guessing it is burning a bit.
tune ups are done frequently, so the engine is well taken care of.
let me know what you think, thanks.
good car, good price.
***2000 dollars***
so if you are interested e-mail me @ CRXLST@AMERITECH.NET thanks.
thanks
omar
***2000 dollars***
thanks
omar
