help a gal out PLEASE
I am in need of some guidence. I have a 91 Acura Legden I need to install a new fuel relay. I can't find it I have the part. need alittle better detail as to where it is located. so I can replace it.
Thanks for the help
Thanks for the help
Main relay?? I don't have a Legend, but Honda usually likes to put those relays above the left kick-panel. Look around the area above & left of the driver's left knee. You'll probably have to remove some trim panels...
The Helms manual would probably be the most thoroughly done book, but the Haynes is cheap and doesn't really help out all that much for some things.
You may find the answer you're looking for in the HAN somewhere.... although I don't think it has the most info on Legends.
Good luck for now. Maybe a Legend-head will pop up soon.
