FS:1991 Crx Si *Upstate NY*
Here are the specs
1991 Honda Crx Si
-134k on chassis
-JDM b16a1 Motor (50-60k on it)
-LS Transmission w/y1 gears
-ACT 6 Puck Clutch w/extreme pressure plate
-ACT 12.5 light flywheel,chromolly
-Driveshaft stage 2 axles
-Hasport Shift linkage w/short shifter
-Hasport Motor mounts
-New Placing Racing Crossmember w/4th motor mount
-JE 9:1 Compression
-Eagle Rods
-Knifedged Crank
-Type R Oil Pump
-Type R Water Pump
-Type R Valves,Valve Springs,Reatainers and Cams
-Brembo Stainless Steel brake lines (Fronts installed,rear ones not)
-MSD 6al Box
-MSD Blaster 2 Coil
-High Flow Cat
-2 1/2" Exhaust w/4 1/2" Muffler
-Neuspeed Race Springs
-KYB 4way (3way?) Adjustable Struts
-Neuspeed Front Upper Strut bar
-Neuspeed Lower tie bar
Story:
The car was a former turbo project car.The turbo equipment was only 3/4 there when i got the car, so I sold the parts and took it back to N/A.
The car will turn over and it does run,but it needs to be completed.Great project but needs some time to be completed,which i do not have.Needs an O ring in the oil pump,but i am having that done.Other than that,it is just a matter of re-mounting the bumper support, bumper, installing the lights/turn sigs,(all of which i have)and it's rolling.Interior is in good shape as well,and the body is in good shape too.
Lots of goodies with this car,so am asking $4000.00 OBO.
Reasonable offers will be considered.
Contact me via Pm,phone or email.Car is located in Ithaca,NY
Cory @ 607-533-4877
1991 Honda Crx Si
-134k on chassis
-JE 9:1 Compression
-Eagle Rods
-Knifedged Crank
-Type R Oil Pump
-Type R Water Pump
-MSD 6al Box
-MSD Blaster 2 Coil
-High Flow Cat
Story:
Cory @ 607-533-4877
