B16A not running right Please Help
Old Dec 13, 2004 | 10:10 AM
civicsirnos's Avatar
civicsirnos
Default B16A not running right Please Help
We just had a first gen b16 put into a 95 civic dx coupe. The motor has been completely rebuilt with new ctr oversize pistons/ crane stage 1 cams/ crane titanium valve springs and retainers/ all new gaskets- bearings etc.../ and we used the obd1 sohc vtec ecu (p28 i think) that has been remapped. The motor now starts and idles ok but will not rev above 3,200 rpms. It seems like it starts to choke at that point. 3 error codes show up -- 1 for a fuel injector and 2 for the vtec solenoid. Those don't seem like problems that would limit the motor from revving. When starting fluid is sprayed into the intake man the car will rev much higher --- Anyone got any ideas? or seen this before???? PLEASE HELP -- we've spent so much on this engine already. oh -- its running on a gsr distributor and injectors.
HELP HELP HELP HELP!!!!
thanks guys
Old Dec 13, 2004 | 01:18 PM
pomansouth's Avatar
pomansouth
check the tps, you said it has three codes, what is the other code.
Old Dec 13, 2004 | 04:14 PM
teg92's Avatar
teg92
WHAT OK YEAH!
try using the b16 ECU, I tried using my stock civic ECU on my LS and it ideled high and ran like shit. I would get the right ECU
Old Dec 14, 2004 | 09:36 AM
civicsirnos
two codes for vtec and 1 for injector, can't use the b16ecu - it's obd0 and the motor has been converted to obd1 to match the car.
Old Dec 14, 2004 | 10:41 AM
Civic2Scooby's Avatar
Civic2Scooby
get the proper ecu or get the p28 chipped....it will run like piss with that ecu in there.
Old Dec 14, 2004 | 05:25 PM
pomansouth's Avatar
pomansouth
he says it has been remapped... anyhow i am guessing that it is the ecu also, what about a p30 ecu since everything is OBD1 now, the p30 will come out of a delsol.
Old Dec 17, 2004 | 11:23 AM
meangreen96's Avatar
meangreen96
Integra Owner No. 122,019
2 cents:
AEM Engine Management. Get it tuned. Your aplication is exactly what its for.
Old Dec 20, 2004 | 07:22 PM
ghettoklepto's Avatar
ghettoklepto
my buddy had same problem with his b16b it was his tps sensor
