need help on pwr windows !
I got a 94 coupe DX, and the previous owner swapped 95 EX doors with pwr windows and door locks on it. both of the doors are hooked to the battery with 20 amp fuses. the only problem is that on the drivers door, i cant control the passengers power window. the drivers door can control the drivers window, and the passenger door can control the passenger window. anyone know which wires to hook up from the drivers door to the passengers door to make it work>?
open up your driver door panel and on the oem switch harness, (hopefully the wires still there) u will need to extend two wires to the passenger side switch. those two wires is blue/yellow and blue/green. on the passenger side oem switch, again hopefully the wires r still there, u just match the blue/yellow and blue/green. after that u will have control of the passenger side. have fun.
thanks..i'll be on it tonight.. now any1 know bout the power door locks? i can lock/unlock only the drivers side with the switch when im inside the car. the passenger lock doesnt lock or unlock. should be some wires.. but dont know which ones
if you can read a wiring diagram see my little write up that explains how to hook everything up.
Outxider is right, but you will have to disconnect the passenger side switch wires he mentions from ground to run them to the drivers switch.
