door
there is is part of the hinge called the checker you can see a picture of it here. http://www.hondaautomotiveparts.com/...ry5=DOOR+PANEL
number 11/15
number 11/15
Do you need to take the door apart to replace it?
number 11/15
number 11/15
and its only held in there by like 3 bolts i believe. i had to remove mine to replace the weather stripping around my g/fs passenger and drivers side door. only takes about 5 minutes to do it
Thanks for the info. I will have to find out which part number to get since there were 2 different part numbers for each side.
