Question about rsx-s
Old Dec 4, 2004 | 11:22 AM
whitewidow's Avatar
whitewidow
HCP Kr3W
Default Question about rsx-s
Do they have eps and ebs?
Also what do they run stock on the quarter? and what does the civic si run stock on the 1/4. Is the type-s That much faster than the ep3's?
THanks
Old Dec 4, 2004 | 04:15 PM
sherwood's Avatar
sherwood
I missed Sean
i think that the rsx uses a conventional steering system.. not sure on ebs tho
and the RSX should blow the Si out of the water on the 1/4 mile, i mean it only has 50 more horse, give or take a few...
Old Dec 4, 2004 | 11:20 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
A base model RSX and Civic Si's have the same HP numbers. They should run about the same in 1/4 mile, probably high 14-low 15s. A 50 hp difference between the type s and the si will bend the si over it's knee.
Old Dec 5, 2004 | 12:04 AM
PikkaGTR's Avatar
PikkaGTR
Power of Dreams
well the base rsx should run nearly the smae 1/4 as the ep3, but the type s with it's 6spd and more aggressive i-VTEC profile and 50+ hp is definitely a lot faster
i think stock times for the RSX-S is somewhere around low 15s to high 14s
14.9-15.3 1/4
Old Dec 5, 2004 | 10:55 AM
sherwood's Avatar
sherwood
I missed Sean
i think the new one is even lower, mid to low 14's now
