Huh? Civic Si = 26/31mpg and RSX = 27/33 mpg
Old Dec 1, 2004 | 04:48 PM
chimchim's Avatar
chimchim
WRX cuz Honda won't wagon
Default Huh? Civic Si = 26/31mpg and RSX = 27/33 mpg
Is this just because it's a hatch vs a coupe style hatch like the RSX? I can't imagine it's because the Civic has more "accessories" or a stiffer chassis than the RSX. What's the deal?
Civic Si = 26/31mpg
RSX = 27/33 mpg
RSX-S = 24/31 mpg
Civic Si = 2782 lbs
RSX = 2694 lbs
RSX-S = 2767 lbs
Old Dec 1, 2004 | 04:52 PM
honda_pilot's Avatar
honda_pilot
DeeCeeFo'
Aerodynamics would be my guess, I'm sure being a hatch there is more turbulence in the rear draft of air behind the Si than the lower rear hatch on the RSX...not a big difference either. Might be error.
Old Dec 1, 2004 | 06:48 PM
George Knighton's Avatar
George Knighton
The USDM EP3 has the Type R axle ratio.
Old Dec 3, 2004 | 12:55 AM
PikkaGTR's Avatar
PikkaGTR
Power of Dreams
i see difference in the 100lbs or so in extra weight the si has over the rsx
Old Dec 3, 2004 | 03:51 PM
sherwood's Avatar
sherwood
I missed Sean
the k20 in the rsx is more power, how can it consume les gas? it just doesnt make any sense
Old Dec 3, 2004 | 08:27 PM
George Knighton
Tap tap tap.... Ummm.... Hello?
Old Dec 3, 2004 | 09:24 PM
sherwood's Avatar
sherwood
I missed Sean
it doesnt matter.... the type-r axle ratio is shorter, if anything it should consume MORE gas
Old Dec 3, 2004 | 09:25 PM
sherwood's Avatar
sherwood
I missed Sean
opps, the ep3 is the civic, i thout it was the rsx, sry, yea that would explain it... why don't they just put the k20 from the rsx into it then with the RSX final drive. if it is faster and more fuel effcient that way, i dont understand why not
Old Dec 5, 2004 | 03:19 PM
motoguy128's Avatar
motoguy128
Fuel mileage is a strange animal. Like mentioned above, gear ratios will make a big difference as does weight and expecially aerodynamics.
However, as for the engine, fuel economy comes from the enignes ability to run lean and still makes good torque/power at throttle positions under 20%. High compression ratios help quite a bit.
Ultimately, teh city numbers are almost the same. THe big difference is in the highway numbers. I suspect that although the RSX does not have a significantly better coeffecient of drag, it does have a slightly smaller frontal area. It's a smaller car than the Civic.
Old Dec 10, 2004 | 09:17 AM
THEOLDMAN's Avatar
THEOLDMAN
Checking it twice
We typically average 25-32 mpg in the RSX-s. I don't just cruise around in VTEC because it sounds cool either. Neither my wife or I are slouches on the gas pedal either and the redline is not a stranger. I typically average about 85-90 on the exways, but stay close to the limit in towns.
