Integra cold weather starting problems
Old Nov 28, 2004 | 07:46 PM
gister's Avatar
gister
Default Integra cold weather starting problems
I have a 1997 Acura Integra which won't start below approximately 39 degrees. At first we thought it was a battery problem, and found the battery was bad, so it was replaced. But the problems continued. The mechanic replaced the starter and tightened some of the connections. It still would not start below 39 degrees. So the mechanic replace the starter again. Same problem. New, different brand starter was put in. Same problem. The mechanic says 12 volts are at the starter when it won't start. The lights on the dash all come on, but there is no sound, except the radio antenna, when it is below the critical temperature. Has anyone experienced this problem?
Does anyone have any suggestions of what to check at this point? Help..........!
Old Nov 28, 2004 | 10:50 PM
wayne99integra's Avatar
wayne99integra
99Turbo GS-R
I have starting problem too when the weather is really cool... but it still start up but just take couple times to start it...
