just installed my new Radiator but one quick question
Old Nov 27, 2004 | 10:34 AM
RpG~^_^~LauRnO's Avatar
RpG~^_^~LauRnO
Default just installed my new Radiator but one quick question
i just installed a new rad in my friend's 94 teg.
anyways, what's the difference between the 2 fans?
i know one suppose to be an AC fan and the other one is for the rad fan, correct?
anyways so the small fan (driver side) would turn on if i turn on the ac, so guess that works so i shut it off. then i waited for another few mins then still only the small fan turns on.. so what's up with the big fan (passenger side)? someone told me that's a secondary fan which only turns on when the engine is too hot is that true? the teg isn't plated so i can't drive around to test it.. the only thing i could do is rev the engine to 3k and let it run for like 10 mins.. all i saw was the small fan..
can someone help me or answer my question plz? i just want to make the big fan turns to see if it works thats all..
thank you
Old Nov 27, 2004 | 11:04 AM
dom93hatch's Avatar
dom93hatch
more meat, more fire
Yeah I think it only turns on for additional cooling, like if you idle for a while it will turn on.
Old Nov 27, 2004 | 11:20 AM
LT's Avatar
LT
The deer had to die!
odd, when i run my A/C both fans start running.
Old Nov 27, 2004 | 11:24 AM
RpG~^_^~LauRnO
yeah that's werid huh~~ i installed a 99 ITR rad in a 94 teg.. from my knowledge there shouldn't be anything different unless i am wrong. Am i?
um... i dont' recall when the engine was cold(99 ITR) but i know for sure when it was hot my both fans turned..
i hope someone on this board can help me..
Old Nov 28, 2004 | 07:10 AM
LT's Avatar
LT
check the relays, electrical test
Old Nov 30, 2004 | 04:05 AM
PlastikOwl's Avatar
PlastikOwl
The fan on the passenger side is the radiator fan. The smaller fan is just a supplement for when you turn on the A/C while idling. The larger fan will take a good 15-20 minutes to turn on after flushing the coolant system. The car has to be completely warmed up for it to turn on.
Old Nov 30, 2004 | 06:57 AM
RpG~^_^~LauRnO
funny thing.. my friend told me the big one is the 2ndary fan which only turns on when the engine reach to a certain temp.
car isn't reg. so can't go on the road to test it and the street is too short to test drive either. i let car idel at 4k for 5 mins, temp stays the same as normal and still only the small fan (AC fan) turns.. werid huh? i guess the only way to find out is to take it on the high way, floor it and see..
the rad was off a 99 ITR installed to 94 SE i hope that's not going to be the cause of it.
Old Dec 1, 2004 | 03:32 PM
integravtec96's Avatar
integravtec96
Both my fans come on when i turn on the a/c on my 96 GSR and to my knowledge both come on when the engine gets hot..hmm
Old Dec 1, 2004 | 09:02 PM
DVPGSR's Avatar
DVPGSR
I need sleep...
Since I removed my AC I have taken the fan next to where the AC compressor and PS pump were and am running just the larger fan next to the intake. I never hear it on but my car never gets more than 1/2 way hot even in the summer in traffic.
Old Dec 3, 2004 | 03:54 PM
RpG~^_^~LauRnO
that's really werid.. my friend insured his car and starting driving on road again.. i drove it last time and noticed his temp was droping while on the free way... do you guys think that his thermostate has something to do, like with the fan switch or something? coz so far.. only still see the little fan runs.. i never seen the big fan turn on yet.. damn it..
it's -10C + snowing outside.. i really don't think i want to go out and check the wiring.. but at least i did check the plugs and they are fine.
anything else i should do? what about the fuse? is there only one fuse for the fans or it's separted???
please help me out guys~
