Oil coming in from floor
93 LS
I removed my floormats to find small streams of what looked to be oil every where on my carpet. I looked thru a hole in the carpet to see oil that looks to be seaping in small areas around the floor. What can be doing this? Clutch master cyl. ? My clutch is a cable i believe. Help Pleez.
Inacurals
Inacurals
It's also possible that your brake master cyl. is leaking..
h:
If that's the case, then I'd park the car until you've got the brakes back in proper working order.
h:If that's the case, then I'd park the car until you've got the brakes back in proper working order.
