help on b20 swap
Old Nov 21, 2004 | 10:38 PM
whiteboii11's Avatar
whiteboii11
Default help on b20 swap
i have a eg hatch and want to put a crv b20 engine in it.. i want to keep it non vtec what are good ways to go about this? i am planning to use a b18b tranny, what ECU is recommended to use? and do other integra b18b parts fit onto this engine like headers? also will the civic axles hold up or will i have to buy crv axles or integra axles better? any other thing i should be aware about that i havent posted please let me know thanks..
Old Nov 22, 2004 | 04:54 AM
bambbrose's Avatar
bambbrose
you have to peice the whole kit together yourself, so It's going to be somewhat difficult.
ecu= p75, which is obd1 ls ecu, and then get a fuel controller to fine tune from there
the b20 and b18b heads are identical, so all the manifolds can be switched, as well as electronics.
You have to get integra axles
there is a lot that you need to know still. don't start buying anything until you think you have figured it all out
