Valve Adjustment required @150k?
Old Nov 16, 2004 | 11:03 AM
will94integ's Avatar
will94integ
Default Valve Adjustment required @150k?
I got this coupon earlier this year from a near by Acura dealer; $399.95 for a 30k service. I wanted to get this work done at dealer so I called four dealers in my area and everyone quoted me $500-600. I asked the dealer with the $399.95 coupon why it's $550 for a '94 Integ RS. She said, well we recommend you get your valves adjusted. It's not necessary every 2 years for all models, i.e. MDX.
So naturally, question is for a stock Integ RS do I really need this valve adjustment now? Or is she blowing smoke up (u know where). $150 is pretty steep unless I really need it. If it makes any difference, I can hear the valves going from inside the car at low idle, but not above ~1,500 RPM.
Old Nov 16, 2004 | 11:30 AM
IrishBrewer's Avatar
IrishBrewer
If they're recommending a valve adjustment without having taken a look under the hood then yes, they are just blowing smoke up your a$$ and out your wallet.
What else are they going to do for $400 for the 30k service? I personally think that many of these scheduled maintenences are a waste of money. Many of the parts can be inspected with relatively little trouble and they can use that inspection to determine what REALLY needs to be done as opposed to what is scheduled to be done.
The big exception to this is your timing belt/water pump job. Do you know when that was last replaced?
Old Nov 16, 2004 | 12:15 PM
LT's Avatar
LT
The deer had to die!
you can do your own 30K-mile service. you can even adjust your own valve clearances! for...12 dollars.
Old Nov 16, 2004 | 12:39 PM
will94integ
last timing belt, hoses & water pump done at 90k...
Old Nov 17, 2004 | 07:02 AM
JimBlake's Avatar
JimBlake
My '95 owner's manual says to adjust valve lash & timing belt tension every 30k miles. So... did you have it done at 120k??
Old Nov 17, 2004 | 08:50 PM
rslsgsr's Avatar
rslsgsr
poor hungry dirt kid
i gotta adjumst my valves... they loud like kamow girls.... go to ti.net and learn
