Anyone chenged their own rotors?
Old Nov 13, 2004 | 11:25 AM
dviii's Avatar
dviii
Default Anyone chenged their own rotors?
how do you removee the rotors? is there a nut in the center, or does it come off when you take the caliper off?
TIA
oh yea what size socket will i need if so?
Old Nov 13, 2004 | 11:45 AM
noahrexion's Avatar
noahrexion
14mm i think, maybe a 17mm to, its been a long time for me. Just take the wheel off, take off the caliper and slip the rotor off the wheel studs. Takes 3 mins...
Old Nov 13, 2004 | 12:14 PM
dubcac's Avatar
dubcac
I
The rotor is held to the hub by 2 phillips screws. You'll need an impact screwdriver to get them off. Do a search, there was a thread not too long ago showing how to change rotors.
Old Nov 13, 2004 | 12:21 PM
bluetwo's Avatar
bluetwo
Relevance is irrelevant
you don't actually need an impact. If you have a large hammer and a flat tipped punch you can break the screws loose. They will be frozen in there if the car is more than a year or two old... So don't just try to turn the screws with only a screwdriver.
Put the flat part of the punch against the screw and whack the sh!t out of it.
This trick will work for allen head screws that are stuck too. The impact causes whatever is stuck to come loose.
Although an impact screwdriver is professional way to do it.
Old Nov 13, 2004 | 12:43 PM
dviii's Avatar
dviii
sweet, so there is no center nut holding it onto the hub?
Old Nov 13, 2004 | 04:04 PM
dubcac's Avatar
dubcac
I
No, that nut is to hold the axle to the hub.
Old Nov 14, 2004 | 08:06 PM
worm696's Avatar
worm696
correct. very easy to do
Old Nov 14, 2004 | 08:25 PM
dviii's Avatar
dviii
thanks guys, they were easy to replace, the screws didnt put up a fight, so it was smooth. thanks!
Old Nov 15, 2004 | 07:18 AM
coolguytoo's Avatar
coolguytoo
those screw are to help you in removal, take the screw out and put then in the other holes and screw them in, the pressure with pop the rotors right off. I had a hard time with mine and i did this and they poped right off, piece of cake!
Old Nov 15, 2004 | 02:50 PM
newgsrdriver's Avatar
newgsrdriver
I wouldnt put those screws back in, theyre useless. If they didnt give you a problem now they will in the future, sometime, somewhere.
