B18B1 94 Civic?
Old Nov 12, 2004 | 01:40 AM
SlowRider's Avatar
SlowRider
Default B18B1 94 Civic?
Can I use a 1997 B18b1 engine in my 94 civic? Will the mounts match up? What transmision would I have to use to match my existing lines? What would I have to do to make it work in my car? Thanks
Old Nov 12, 2004 | 06:56 AM
carlitosir's Avatar
carlitosir
YES! and please boost it :P
Old Nov 12, 2004 | 07:28 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Check the hybrid section in the Online Resources sticky in the Civic forum. That should get you started.
Do you have auto or manual? You will at least have to get the A/C, Upper Driver's side, and rear Tortion mounts from the Bseries. Which tranny you have will help determine which mounts you will have to use there.
Try searching and researching this stuff in this section. This has been covered many times in the past.
