Installing JDM Type R Cluster into 95 LS
Old Nov 11, 2004 | 09:44 PM
j87w's Avatar
j87w
Default Installing JDM Type R Cluster into 95 LS
I want to buy the JDM Type R gauge cluster for my 95 LS. Does it matter if it came out of a 96 or 98 spec? Will all the wiring be the same. Like will it just be like swapping the a cluster. Thanks
Old Nov 12, 2004 | 01:00 AM
honura's Avatar
honura
Seni
Nope! The cluster you wanna buy is OBD2 and your tegra is OBD1
Old Nov 12, 2004 | 08:00 AM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Negative, Ghostrider.
Wiring changes will make this cluster swap [nearly] impossible.
Old Nov 13, 2004 | 09:01 PM
b-power's Avatar
b-power
b-power
get the 96 and switch the green sheets or else there is some repinning involved. if you are lucky you can get the cut harnesses from the 96 and just wire them in
Old Nov 14, 2004 | 01:57 PM
95tegRS's Avatar
95tegRS
you can always swap out the guages and carbon fiber outlay in the JDM unit, and put them in your stock unit.
I have just heard that the obd2 units will make wierd lights come on, and your fuel and temp needles will probobly start reading incorrectly.
but its not impossible, just a few more steps. good luck
Old Nov 15, 2004 | 09:55 AM
DVPGSR's Avatar
DVPGSR
I need sleep...
This is the best route to go...I did this on mine when I got a 97 JDM ITR cluster without the airbag plug.
Old Nov 18, 2004 | 08:47 PM
j87w's Avatar
j87w
How do you swap them? Do they just pull off or what? I dont really care about the carbon fiber. Just the gauges and needles.
Thanks
Old Nov 18, 2004 | 09:14 PM
HaHAAHhAHHAH's Avatar
HaHAAHhAHHAH
Banned
got any pics of this?
Old Nov 19, 2004 | 05:49 AM
DVPGSR's Avatar
DVPGSR
I need sleep...
No sorry...but i could show you pics of it installed but that will not really help. Basically look at the clusters and you can easily see how the plasit pieces come off from their tabs. Then the actual guages are held into the cluster by screws you can see at the back over the green film.
Old Jan 20, 2005 | 04:56 PM
95tegRS's Avatar
95tegRS
behind the cluster there are like screws holding the guages in place. one by one, unscrew them. I think its like 2 or 3 for each guage. You need a skinny long phillips. and then its just the matter of swapping the guages (and carbon fiber piece if you want) onto your old unit.
