How To get the ECU codes 92 ls
Old Nov 11, 2004 | 10:15 AM
xstatic's Avatar
xstatic
Default How To get the ECU codes 92 ls
ok i've been trying to find out what i need to do in order to get the ecu codes
i've tried another integra forum but its not helping at all
can anyone tell me what i need to do in order to get these codes on a 92 LS... thanks for the posts in advance...
ps i've already tried searching for it but came up with nothing.
Old Nov 11, 2004 | 11:41 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
Go to www.c-speedracing.com. Under the FAQ section, it will tell you.
Old Nov 11, 2004 | 03:26 PM
carta79's Avatar
carta79
Life after death
He has a G2 though. I thought the G2s have the ECU with the LED instead of connectors.
Click here for TI article
I'm not sure if you have to register to view this article.
Old Nov 11, 2004 | 03:52 PM
xstatic's Avatar
xstatic
ay man appreciate your post but thats for a 90-91....i have a 92, we pulled up the carpet a while ago and theres no led light on the ecu we even took the ecu out to look around for it but negative.
Old Nov 12, 2004 | 01:03 PM
xstatic's Avatar
xstatic
still cant find the connector..
Old Nov 14, 2004 | 05:57 PM
noahrexion's Avatar
noahrexion
The connector you must jump is located under the glove box and should be green in color. How to jump -- Helms: Chapter 11 page 40
Old Nov 14, 2004 | 07:09 PM
dubcac's Avatar
dubcac
I
OBD0 ECU's have the light on the ECU that blinks. His car is OBD1.
How to check:
http://www.c-speedracing.com/faq/06.php
Code listing:
http://www.c-speedracing.com/faq/05.php
