Turbo BOV
Old Nov 8, 2004 | 08:35 PM
Kabooki's Avatar
Kabooki
Default Turbo BOV
does a turbo setup HAVE to have one? is it just HIGHLY recommended? im in the midst of gettin a full turbo kit w/o bov for $700
your thoughts?
Old Nov 8, 2004 | 08:38 PM
lkailburn's Avatar
lkailburn
college kid
yes you need one. without it you are likely to get compressor surge which can be very damaging to the seals etc of the turbo.
atleast pickup a cheap bov from a junkyard or something. aslong as it functions properly.
1g dsm's are popular.... i've got one
Old Nov 8, 2004 | 08:42 PM
jeterkm02's Avatar
jeterkm02
hatchbacks r my anti-drug
when you let off the throttle, the turbo is still spooling, that pressure has to escape somewhere, so yes you do need a BOV.
Old Nov 8, 2004 | 09:00 PM
Kestrel's Avatar
Kestrel
Push to shock!
And how else are you going to get that blowoff valve noise :-)
Old Nov 8, 2004 | 09:16 PM
jeterkm02's Avatar
jeterkm02
i wish i didnt have one.
Old Nov 9, 2004 | 04:19 AM
Kai's Avatar
Kai
Rotorphile.
Yes, you need one unless you want to blow your turbo. If you don't want the noise, recirculate it back into the intake system before the turbo. There are a few aftermarket BOV's (like the Greddy Type S) that have special ports to allow for this.
Old Nov 9, 2004 | 04:24 AM
monicle's Avatar
monicle
Repo.Jackmoves.Com
It is "possible" to run a turbo without a BOV however I dont reccomended it for anything over 5psi as it will cause surge and eventually lead to an early rebuild/repair of the turbo.
Old Nov 9, 2004 | 07:18 AM
Paul's Avatar
Paul
Eater of Rice
how come turbo diesels don't have BOV's/bypass valves then?
Old Nov 9, 2004 | 07:21 AM
Kai's Avatar
Kai
Rotorphile.
No idea, I've never worked with a turbo diesel. The whole "no sparkplug" thing really bothers me.
Old Nov 9, 2004 | 07:27 AM
WideBodyEK's Avatar
WideBodyEK
Stage 3 Modified
have you never took off from a light with a semi truck in the lane next to you and tried to time your shifts with his so it sounds like your car has a bov? :chuckles: alot of semi trucks/turbo diesels have BOVs,..and they are loud too
