headlight question
Old Nov 8, 2004 | 07:52 PM
worm696's Avatar
worm696
Default headlight question
is it possible to make the big headlight the high and low beams? one bulb.
Old Nov 9, 2004 | 04:39 AM
Kai's Avatar
Kai
Rotorphile.
Sure, with some modifications.
Old Nov 9, 2004 | 04:40 AM
Kai's Avatar
Kai
Rotorphile.
(double post)
Old Nov 9, 2004 | 10:20 AM
worm696's Avatar
worm696
Originally Posted by Kai
(double post)
ive searched could you provide me with the info please, or link?
Old Nov 9, 2004 | 11:11 AM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
What year Integra? Why do you want to that anyways? Are you thinking ofg a coversion that only has one headlamp? Instead of two? I believe you would need a bulb that is 9004 or 9006 high & low beam, then you would need to butt splice your high beam wires into your low beam wires. That or I think there is an adaptor for it. Contact Matt Bourgo at www.darksidemotoring.com
he has a one head lamp conversion on his Integra, ask him what he did.
Old Nov 9, 2004 | 11:17 AM
worm696's Avatar
worm696
thanks. i just want ot be different
Old Nov 10, 2004 | 02:06 AM
Kai's Avatar
Kai
Rotorphile.
Yeah, I was thinking a 9004 bulb like the 84-87 Civics used. Modify the housing, find and wire in a 9004 plug, and go.
Old Nov 10, 2004 | 10:59 AM
worm696's Avatar
worm696
sounds good. thanks for the advice, whenever this project gets done ill try to post a vid of it working.
Old Nov 15, 2004 | 07:04 PM
worm696's Avatar
worm696
what cars could i get the harness from at a junk yard, that would be easy to use for this mod?
