Civic needs some loven' care
My wife has a '90 honda civic and we would like to change the shocks...we have done work on the car before so we are not afraid to get dirty.
What things should we be aware of before doing this? Is it easy to do? Do we need any special tools?
Thanks
Thanks
All you really need in terms of special tools is a spring compressor. It shouldn't take too long. Go to www.deepstaged.net for the procedure if you aren't sure. The install it shows is for changing the springs but it should work.
Just be patient because some bolts are really tough to get off.
Good luck.
Good luck.
thanks for the info...that website is great, it even has pictures to show what is going on. The bolts I realize are going to be a pain...what is a good way to remove them if they are sezied? Should I have a torch handy?
Penetrating oil. Does good things.
And what shmoo said: big ass breaker bar. If you happen to have a really big wrench (like a 1-inch size--those standard wrenches ain't good fer much anyways
), you can loop that around the end of your wratchet handle and it functions pretty damn well as an extension for extra torque. Have fun, be safe.
