Trying to find a part...
Old 10-28-2004, 10:53 AM
Laura
simply lost
Laura's Avatar
Default Trying to find a part...
Unfortunately I do not know what this part is called.. but it connects to the suspension and is apart of the subframe.
I need to find one for the Passenger Rear of my car. The existing was cut out by a former owner after an incident.
Also, would this part be compatible with an EG civic? I have seen what seems to be the samething on the car but am not sure if it will fit the integra 96 LS 2 dr.
ok here is the side I am looking for. The pic should give you a better idea where it is located on the subframe.
That piece that looks like p00 is the piece that I am trying to replace. The first pic that I showed you is what it is supposed to look like.
does that help? []
Old 10-28-2004, 11:05 AM
LT
The deer had to die!
LT's Avatar
can you get a pic zoomed out more?
Old 10-28-2004, 03:32 PM
Epoch
CHRISTMASTIME IN IRAQ
Epoch's Avatar
You mean... that (missing) metal flap covering what looks like some form of sway bushing? What about it do you need to replace?
(What would help is more pics, and circle the part in red in MS paint or such)
Old 10-28-2004, 06:40 PM
fgfournet
R ENVY
fgfournet's Avatar
I don't know why you would need it. The metal covering was removed because the original is welded to the frame so that it can slide back and forth when the bolt is loose. You can see that the nut that was in that original housing has been broken off and the factory nut was replaced by a non-OEM part. I think it is best left like it is. I don't know what the part is called but I know it is on the trailing arm on the rear suspension, if anyone else wants to know what it is (the part furthest to the front of the rear suspension setup), I THINK?
Old 10-29-2004, 07:58 AM
Laura
simply lost
Laura's Avatar
Here are some more pics:
Old 10-29-2004, 10:50 AM
Epoch
Epoch's Avatar
short of welding a new plate over that, I'm not sure if that can be fixed, or more importantly, needs to be fixed. Why are you looking to repair it?
Old 10-29-2004, 12:15 PM
Laura
simply lost
Laura's Avatar
That piece is welded to the frame and that piece also has an arm from the suspension bolted to it.
The piece is separating it from the frame and the hole where it is connected to the suspension is rusting.
Also, I don't want to track the car in this condition. Let alone lower it. I wouldnt be safe.
Old 10-29-2004, 01:33 PM
LT
LT's Avatar
take it to a body shop, they'll know what to do.
Old 10-29-2004, 03:07 PM
Epoch
Epoch's Avatar
:werd: they may just have to custom fabricate something to get it to work. you might be able to also get something off a junked integra too, but either way, it will take a competent body shop to do it right.
Old 10-30-2004, 08:52 AM
Laura
simply lost
Laura's Avatar
Originally Posted by Epoch
:werd: you might be able to also get something off a junked integra too, but either way,
That is what I am trying to do...
