fender rubbing? 17" rims and 1.5 drop
Old 10-27-2004, 11:13 AM
Integra_95
Integra_95's Avatar
Default fender rubbing? 17" rims and 1.5 drop
hi,
I have H&R Spring with 1.75 Front and 1.5 back drop on my integra. I just bought 17" rims with 205/40/17 tires.
Can I put my rims in without any rubbing? I put the tire 17" tire side by side with the car, I do see that it touches the fender.
Any solution/suggestions?
I am thinking of doing a fender roll, is it gonna work?
thanks so much.
Old 10-27-2004, 11:23 AM
94civicEX
I got worms.
94civicEX's Avatar
Are you sure it's touching the fender? Is it when you turn or when you hit a bump?
What shocks do you have?
99 Integra GSR
06 TSX
duck squad member #00003
Old 10-27-2004, 11:26 AM
Integra_95
Integra_95's Avatar
I am not sure because i didn't put it in yet. I have KYB AGX shocks.
When I put the tire by my car, I do see that i touches.
Is it gonna be ok? I don't want to waste money on labor and having it return later.
thx
Old 10-27-2004, 11:40 AM
94civicEX
I got worms.
94civicEX's Avatar
thx
Oooh, can you put, lol, sorry. I thought it was an existing problem.
I had Comptech Drop Springs (1.25/1.5), and 17x7.5 205/40/17, I never had a problem with rubbing on the fenders. I would rub on the firewall when I'd turn my wheels all the way, but it was nothing major.
99 Integra GSR
06 TSX
Old 10-27-2004, 11:59 AM
brothalynchhung
brothalynchhung's Avatar
i have 18's with a H&R 2 inch drop and i dont rub at all (i have very low profile tires mind you.) just my front mud flaps every now and then run the ground... but who cares right.
Old 10-27-2004, 02:08 PM
Nelson
Administrator
Nelson's Avatar
If you are using the correct offset 17" wheels, you should not have issues. I only rub when I have a few people in the car. I have the same exact setup as you. (H&R & KYB)
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old 10-27-2004, 02:21 PM
ADRONICUS
www.ufc.com
ADRONICUS's Avatar
I agree, if the offset is correct your good to go. I am dropped 2 inches w/17's and 205/40's. It never rubs, on bumps, dips, turns, you name it, it is fine. Also, don't roll your fenders, you'll run the chance of cracking the paint and then it'll look like shit.
Old 11-01-2004, 05:15 PM
ZiGeNX77
ZiGeNX77's Avatar
what IS the correct offset (for a 94-01 Integra)?
Old 11-01-2004, 06:19 PM
ChassisInnovations
HAN Authorized Vendor
ChassisInnovations's Avatar
Put the tire on, drive around, and see if it rubs.
Most wheels for the 94-01 Integra have an offset of 38mm or 40mm, though I have seen 36mm, 37mm, and 42mm as well. My 16" OZs have a 37mm offset and I have no problem with rubbing; I have AGX shocks and Comptech springs.
Old 11-01-2004, 09:25 PM
joshman
joshman's Avatar
they will not rub dont worry about it. you cannot tell by putting the wheels and tires up to your car, they will be totally different on your car than if you just set them by your car.
