93 civic with 90 000 miles, what sort of things need to be serviced on it?
Hi I’ve got a 93 civic D16Z6, its done about 93 000 miles and I was just wondering what sort of things need to be checked/changed now like the value adjustment or timing belt?? I've recently changed my tranny and clutch so the tranny has pretty new oil in it, and there’s a new clutch on the car. Any help would be greatly appreciated..
cheers
cheers
Timing belt & valve adjustment. Maybe the water pump since it's right there at the timing belt?
Fresh brake fluid & fresh antifreeze every 2 years. When's the last time for that?
How about brakes? You can't predict that with mileage, since everybody drives differently. But it can't hurt to inspect them real good.
While you're doing the timing belt/water pump you may as well replace your accessory belts (power steering, a/c, alternator). You'll be draining you coolant so check your hoses and replace them as needed. Sounds like you should be in good shape otherwise.
