jack w/ jack stands or ramp
Old Oct 17, 2004 | 05:21 PM
knowjack's Avatar
knowjack
Default jack w/ jack stands or ramp
what's better to work with? safer?
Old Oct 17, 2004 | 05:24 PM
teg92's Avatar
teg92
WHAT OK YEAH!
I think both are pretty safe you just got to make sure you put the jack stands where they go.
Old Oct 17, 2004 | 06:01 PM
oei28's Avatar
oei28
They are both safe unless you have some cheap ones. Don't risk your life to save a few bucks.
Old Oct 17, 2004 | 06:52 PM
knowjack's Avatar
knowjack
what if my drive way is slightly inclined?? Not enough to be noticed, but enough that the car moves in neutral..
Old Oct 17, 2004 | 07:26 PM
Kai's Avatar
Kai
Rotorphile.
It doesn't matter if it's only a few degrees off horizontal. In more extreme cases, use jackstands. If you have a ski slope driveway, find a better place to work.
Old Oct 18, 2004 | 08:45 AM
flyromeo3's Avatar
flyromeo3
if you have a ski slope driveway, use the ramps.
At least if the car is uneven the ramps are better. in my opinon.
Old Oct 18, 2004 | 10:46 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
Ramps are good unless you plan on taking off the wheels...like working on the suspension. In that case, jack stands are better.
Old Oct 18, 2004 | 05:17 PM
kiet's Avatar
kiet
02 silvaccord V6 coupe
my bro uses the jack stand he sticks a big block wood if he ever does under the car for added safety..
Old Oct 18, 2004 | 06:15 PM
wedley2's Avatar
wedley2
bboy Wesley West
ramps are safer but kinda get in the way sometimes.
Old Oct 19, 2004 | 12:52 AM
k.a.y's Avatar
k.a.y
If you place the jackstands correctly, I don't see how ramps are better at all. Also, if you car is lowered any signifigant amount, ramps won't work. Your front bumper will hit the ramp way before your wheel does & it'll just push it accross the floor....
