stuck in park and ignition wont turn
Old Oct 2, 2004 | 04:50 PM
shottie's Avatar
shottie
Default stuck in park and ignition wont turn
I took ignition out after losing key, then when I found it, I connected the ignition back up only to find that the ignition will turn on half way where you can turn heater on but wont start and the gear stick is stuck in park. What do I do, anyones help will be very much appreciated. Oh yeah, my car is a Honda vigor.
Old Oct 2, 2004 | 11:25 PM
88IntegraRS's Avatar
88IntegraRS
Well, the gear stuck in park is a safety feature due to the ignition not being turned over -- a pain in new cars, since you cannot easily shift to neutral for a tow when your key is lost. Have you consulted a repair manual for the ignition installation? I've only done an ignition once, and it was easy, but on an old 67 Mustang. There were grooves to make sure the ignition could be aligned only 1 way. Does everything look aligned correctly, ie does the key point to the correct indicators for off, acc, on, etc? If so, I'm not sure what the problem is, but maybe try the ignition switch for rotation when it's not installed . . .
