Header Gasket
Old Oct 2, 2004 | 02:45 PM
joey t's Avatar
joey t
Default Header Gasket
I Installed A Header On My 2003 Civic A Few Months Ago. I Just Noticed Today That The Gasket I Made Is Starting Too Fall Apart. Its A Cork Type Material The Guy At The Part Store Told Me To Use It. What Type Of Gasket Materiale Should I Get And Where Can I Buy It At. Thanks For Your Help.
Old Oct 2, 2004 | 03:03 PM
lkailburn's Avatar
lkailburn
college kid
??? why did you double post tihs?
Old Oct 2, 2004 | 03:05 PM
joey t's Avatar
joey t
was just trying to get a quick anwser sorry. theres a small piece of my header gasket missing. is it okay to drive the car like that. so new to this honda thing
Old Oct 2, 2004 | 05:50 PM
lkailburn's Avatar
lkailburn
college kid
well you may or may not have a leak with a chunk of your gasket missing. go get an oem gasket from a honda dealer. its most likely a metal gasket.
Old Oct 2, 2004 | 11:29 PM
88IntegraRS's Avatar
88IntegraRS
The guy at the parts store is an idiot -- cork is never used for hi-temp gaskets like a header! Gaskets used for exhaust temps like headers and EGR usually have a coating like perforated aluminum foil. Check out the original gasket, or just get a factory gasket and you should be in business.
Old Oct 3, 2004 | 08:10 AM
joey t's Avatar
joey t
okay im going monday and buying 1 from the honda dealer. my only other question is when i put the header on the car the header is slightly bigger then the factory part and if i use a factory header gasket will it still work?will it make a nice seal? thanks
