92 civic ex sedan starter problems
Old Feb 8, 2016 | 11:42 PM
RonaldRaygun25's Avatar
RonaldRaygun25
Default 92 civic ex sedan starter problems
So I have a 92 eg sedan with a d16z6, for some reason it will not start. It won't crank or make any noise besides the fuel pump engagement. The battery, ignition switch are fine but I have to jump the starter. I'm so lost on what could be causing this issue. Any advice is much appreciated. Thanks in advance.
Old Feb 11, 2016 | 07:25 PM
ChrisS's Avatar
ChrisS
Battery condition?
(fully charged)
Both battery terminals clean and tight?
(positive terminal supplies current directly to starter, negative terminal provides a path for current to flow from all electrical devices in car)
take care,
ChrisS
Old Feb 11, 2016 | 07:38 PM
RonaldRaygun25
Everything is good there. I feel like it may be the ignition switch, but I don't wanna have to spend $140 on a new one.
Old Feb 12, 2016 | 12:55 AM
ChrisS's Avatar
ChrisS
Main relay?
(under the dash near drivers side door hinge; cold cracked solder in it can cause starting problems)
take care,
ChrisS
