Get rid of beeping
Old Sep 16, 2004 | 02:13 AM
Namek's Avatar
Namek
Default Get rid of beeping
I have a 98 civic ex and every time the drivers door is open, the beeping drives me insane... how can I stop it?
Old Sep 16, 2004 | 10:27 AM
TekScream's Avatar
TekScream
Worms For Mayor
is there a switch on the door? that could be it. or you could follow the wire under the hood and basicly disconect it, get some electrical tape and seal her up. if you had a manual im sure it'd help you out a bit. especially in the diy section.
Old Sep 16, 2004 | 11:38 AM
JimBlake's Avatar
JimBlake
First figure out what it is...
Is it the headlights-on chime? Keys-in-ignition chime? Something attached to an aftermarket alarm? How you fix it depends mostly on what it IS.
Old Sep 16, 2004 | 03:48 PM
waleylim's Avatar
waleylim
If its a factory installed beeping sound, remove the door panel and you should be able to see three wires (depending on models) running from the door lock. There should be a black wire that will ground the electrical signal coming from the other wires triggering the warning whenever the door is opened. Cut one wire other than the black one and it should solve the "problem". Before you reinstall the door panel, open and close the door a few times to check if any other stuff in the car is affacted ***Note the "door open" indicator on the cluster...just to be safe.
Old Sep 17, 2004 | 07:26 AM
wedley2's Avatar
wedley2
bboy Wesley West
dayum, it really drives you insane? just close the door, haha.
Old Sep 17, 2004 | 07:36 AM
Archon810's Avatar
Archon810
when i had a jetta, that car's sound was driving me insane. so i found a relay in the relay box, and took it out. the beeping was gone. not sure about hondas, check if u have one too, or maybe call up the dealer real quick. it's worth finding out, cause u dont have to cut any wires, and can put that relay back in no time (that is if u ever want to)
Old Sep 18, 2004 | 06:26 PM
Relic1's Avatar
Relic1
Teal Hatch Cult Member
either you have the headlights on or you have the key in the ignition. When you open the door it beeps to let you know something isn't right to leave the car.
or is this anytime you open the door? even with the car running? then there is something wrong.
Old Sep 18, 2004 | 11:37 PM
Namek's Avatar
Namek
just a door open warning after the car is turned off and the door is still open
Old Sep 18, 2004 | 11:39 PM
wedley2's Avatar
wedley2
bboy Wesley West
yea, i get thta sometimes in my 4th gen, dont really care though.
Old Sep 18, 2004 | 11:51 PM
Namek's Avatar
Namek
Yeah well I sit alot with the door open when im just resting, need a place to sit, or am working on the interior and with it being open constantly... that means there is a constant beep for 20 min straight.
