for sale 90' civic hatch w/ls vtec swap huge mods list
Old Aug 29, 2004 | 05:58 AM
jdmb16civic's Avatar
jdmb16civic
Default F/S- 90' civic hatch w/ DOHC VTEC huge mods list $4500 or trade for bike
LS DOHC VTEC swap w/ 5spd cable trans/ The car is very fast and will spin the tires lose easily in 4th gear! REDLINE IS 9500 RPMS and will hit 120 in 4th like nothing.(over $6000 invested) HERE ARE THE MODS.....
-DC SportsHeaders/PlaceRacing Mounts&Shift Linkage/ACT stage3 Street-Strip Disk/ACT ExtremePressurePlate/Fidanza lightweight Flywheel/New Honda OEM Pilot Bearing/Release Bearing/Front&Rear Main Seals/Water Pump/Timing Belt/.AEM Cam Gears/AEM Fuel Rail/Aem fuel pressure regulator/Superflow high flow fuel filter/Integra Type R Intake Manifold/Civic Type-R ECU/Unorthodox Racing Crank Pulley/Short Shifter/New Tie Rod Ends/New Axles/New Front & Rear Brakes/Drilled & Slotted Front Rotors/New Tokico Struts/Skunk2 Coilovers /Freedom design front Strut bar/DC Sports Rear Lower Tie Bar/Apexi Muffler w/Custom Bent Pipes/SS Cat Replacement Pipe/Accel Plug Wires/DAC cold Air Intake./ Kenwood CD Player w/Alpine Type R Front Speakers/CRX front Si Seats/ Autometer Pro-Comp ultra-lite VACUMM & Volts gauges /Apexi AFC controler /Sparco steering wheel/clear corners/JDM front bumber/Electron blue paint/shaved anttena/Viper alarm
ASKING $4500 or trade for sportbike
EMAIL AT- LIEUTDANL1@COMCAST.NET
FOR PICS CLICK HERE http://home.comcast.net/~lieutdanl1/...ome.html-.html
