i'm stuck in a river
Old Aug 25, 2004 | 02:13 PM
matthewchr's Avatar
matthewchr
pissed off
Default i'm stuck in a river
my car sucked up water through my AEM cold air intake and died. My mechanic says i need a new motor. Please help and give suggestions for new motor swaps if applicable.
Old Aug 25, 2004 | 02:51 PM
9600baud's Avatar
9600baud
JDM rox ur world
:doh: what car do even have?
Old Aug 25, 2004 | 11:39 PM
kluckerz's Avatar
kluckerz
ive got a cold air intake too with no bypass valve... where you driving in the rain or through a small little puddle of water ? i just want to have an idea how much it takes to f'up the motor
Old Aug 26, 2004 | 03:11 AM
BBProductions's Avatar
BBProductions
'96 4Dr Honda Civic
Default are you serious
why wouldn't you all just buyt a bypass valve? :screwy:
instead you wait till your engine is full in water. :eh:
or you are wanting to know how much it takes before it fills up? :stupid:
...are you serious? buy a bypass valve their dirt cheap and it saves your engine... :eekno:
Old Aug 26, 2004 | 04:12 AM
dawrenn's Avatar
dawrenn
Can you use a bypass valve on an AEM V2 CAI?
Old Aug 26, 2004 | 11:27 AM
matthewchr's Avatar
matthewchr
pissed off
99 integra LS
Old Aug 26, 2004 | 11:29 AM
matthewchr's Avatar
matthewchr
pissed off
I drove through a flooded road but i was going 80 when i hit the water. I don't have a bypass valve and the water was about 4 inches deep.
Old Aug 26, 2004 | 11:30 AM
KAUAI KANE's Avatar
KAUAI KANE
91' Toyota Supra
From: Iwakuni, Japan. And where ever the Marine Corps sends me
plain and simple no
Old Aug 26, 2004 | 11:47 AM
cyclops755's Avatar
cyclops755
Just so you guys know, there's a reason AEM is (if not the only), one of the very few companies that makes a bypass valve for intakes. There have been many reports that due to their design, they're defective. People have had the cotton filter element inside the bypass valve housing repeatedly break free and get sucked into the engine, giving them a slightly bigger problem than just a little water in the engine. They won't even carry them in any stores around where I live.
If you set up your intake right, you won't need a bypass valve most of the time. The only thing you really need to worry about with water in the intake is hydro-lock, where there's so much water in the engine that your piston rods have no where to go during the combustion cycle of their stroke, except for through the wall of your engine block.
Now, I'm not saying that some water through your intake is a GOOD thing, but much of the time, the small amount will evaporate, and be able leave your engine for all intents and purposes unharmed.
Just thought it was something to be aware of before you go online and buy one.
-Good luck with it all though!
Old Aug 26, 2004 | 02:21 PM
alphaxxn's Avatar
alphaxxn
4500rpm hesitation
actually , it can be a good thing.. Thats why alot of evo owners and such set up systems to spray a super-fine mist of water thru intake, it cools engine temperatures.
Anyhow, if the engine hydro-locked, youll more then likely need a mostly new engine. I have heard quite a few horror stories, but never really seen consistent results due to hydrolock, some people screw up rods and pistons, some people screw up just rods.. kinda a crapshoot.
