How much to Replace Transmission and Clutch on a 2001 Type R?
Old Aug 17, 2004 | 04:41 PM
ITR0952's Avatar
ITR0952
Default How much to Replace Transmission and Clutch on a 2001 Type R?
Parts plus labor, I know it's not going to be accurate, but I just want a estimate number.
thanks,
How many miles will they need to be replaced?
Old Aug 18, 2004 | 04:21 AM
BudMan's Avatar
BudMan
aka - dnfjeff
There shouldn't be any reason to replace the tranny.
If you need to replace the clutch & assembly (pressure plate, throwout bearing) then expect ~$300-400/parts for something worthy like clutchmasters stage 3 setup (highly recommend it for street or HPDE use).
I also recommend jumping up to using the flywheel (plus pilot bearing) from clutchmasters ~$250-350/parts.
The swap is a pita until you've done a couple & then you realize it's not that hard to do on your own & save the labor (Acura will charge ~$500 for labor alone.
If you have to replace/rebuild the tranny(gearing/case) I hope you have deeeeep pockets - labor will kill you unless you can do it yourself or have someone you can just take the case to after YOU have pulled the tranny yourself.
Old Aug 18, 2004 | 08:58 AM
sensei's Avatar
sensei
I was quoted ~$2100 for the trans at a local dealership here in MI.
I highly recommend the CM stage 3 clutch as well...I've had it for 2+ years with ~100 drag launches and the thing still grabs and does not slip whatsoever...the engagement is also very, very stock-like.
