Hesitation under load
Old Aug 17, 2004 | 01:34 PM
GaryS's Avatar
GaryS
Default Hesitation under load
Our 95 Integra is hesitating, with pretty significant "jerks", under heavy load. I can accelerate to redline in the lower gears on flat terrain. Going up a steep hill and using anything more than normal gas pedal position causes some serious intermittant bucking. I thought it was the fuel filter so I replaced it and the air filter. It still does it. The hesitation is so sharp that it feels ignition related. It only seems to do it in the higher gears, 3rd, 4th, and 5th.
Any ideas on what it could be? Weak fuel pump? Coil? Something related to gear position and throttle position? Flux Capacitor? (anyone remember what this last one is from?)
Gary
Old Aug 17, 2004 | 11:04 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Distributor?
Old Aug 18, 2004 | 05:23 PM
GaryS's Avatar
GaryS
Distributor? Is that a guess or are you basing your response on something?
Gary
Old Aug 19, 2004 | 04:21 AM
JimBlake's Avatar
JimBlake
Maybe he's guessing where the flux capacitors are located?
Sharp misfiring does sound like ignition. How old are your spark plugs? Take 'em out to check their condition even if they're not too old. How about plug wires, cap & rotor? Try looking for arcing in the dark.
Old Aug 21, 2004 | 02:19 PM
GaryS's Avatar
GaryS
New plugs, wires, distributor cap and rotor along with a new timing belt about 40000 miles ago. I am leaning towards all new components again. Cheap insurance for around $100.
Gary
Old Aug 23, 2004 | 03:33 PM
thedad's Avatar
thedad
Start with the plugs and work your way out. The timing belt would be my last resort. :cheers:
Old Aug 23, 2004 | 06:17 PM
nonturbo's Avatar
nonturbo
nonturbo
i will recommend do a good tune up,check the spark plug wire, cap, rotor,it usually solve the problem for the situration,conz i am a mechanic
